Are Gizmoproject users reachable via SIP
Oct 31, 2005 3 Replies
Wolfgang S. Rupprecht
Sipphone (unlike some the bigger players) is a good VOIP citizen and allows incoming VOIP calls. The best scoreboard that I've been able to find is for who allows direct VOIP calls is the one at sipbroker: / Free-World-Dialup also has one too, but it isn't as complete: addition…
Are Gizmoproject users reachable via SIP from others who are not currently registered with the Gizmo project? If so, what does their SIP URI look like? snipped-for-privacy@gizmoproject.org does not seem to do the trick.
snipped-for-privacy@proxy01.sipphone.com
The "x"s are digits.
Thanks. Is this documented and officially supported?
Pulver / Free-World-Dialup also has one too, but it isn't as complete:
In addition to software clients, anyone that has programming control over their ATA should be able to make direct VOIP calls by using either one of the above free services. I don't think one needs to register with either one for them to redirect your call for you.
-wolfgang
