[ANN] A bugfixed YATE port is available for FreeBSD
Mar 05, 2007 1 Replies
Greetings!
Yate is a telephony engine aimed at creating a telephony softswitch that performs well enough to deal with the PBX (Private Branch eXchange) requirements, ACD (Advanced Call Distribution) and also flexible enough for complex VoIP (Voice over Internet Protocol) Gateway, Conferencing and IVR (Interactive Voice Response) solutions. Currently, all popular packet voice and, or software protocols SIP, H.323, IAX2 and Jingle as well as traditional TDM hardware including many a T1, E1, ISDN PRI and ISDN BRI are supported over various signaling protocols.
WWW:
An updated yate port is available for FreeBSD, I don't have enough of the resources to test; it however, is possible to build the same on other *BSD variants too.
To install/upgrade the ports download:
To extract: # tar jxvf /yate.tar.bz2 -C /usr/ports/net # tar jxvf /spandsp-devel.tar.bz2 -C /usr/ports/comms # cd /usr/ports/net/yate # make install
or
# make package
NOTE: Before running csup and, or cvsup do create and, or update a refuse file:
# cat /usr/ports/refuse comms/spandsp-devel* net/yate* EOT
A yate ports collection for FreeBSD created by Alex Rodin 'alex DOT rodin AT gmail DOT com' is also/already available in the yate mailiing list archive.
Kindly note, that this one is different and also includes, though small, but the following enhancements over the latest CVS head:
  • On Unix systems yate daemon tries to run under normal uid and, or gid.
  • Loading and, or initialization messages moved to highest debug level.
  • Support for aliases is added to module regfile; check status now shows aliases as 'alias->number'.
  • The status now shows ip:port for remote connections in the rmanager module.
  • Updated and, or upto-date manpages, README and INSTALL files.
I'm not that much expert in SIP, H.323, IAX2 and other such protocols and, or PSTN technology, so I request you to please post your relevant and, or technical questions to Null Team only; the creators of yate at
Thanks, Regards,
Mr Aivis Olsteins reported a minor problem in building Yate on FreeBSD, this has been corrected please read
for further details.
I have not submitted these ports to FreeBSD collection, 'cause that system exposes e-mails openly and encourages spammers implicitly, but I shall feel obliged if the FreeBSD and, or other BSD variant's ports management team merges this with their official ports collection.
Thanks, Regards,
