I just got a 900 MHz DSS cordless phone, and I had the perfect spot
> for it, right on top of my tower computer case. But then I noticed
> that the manual says that the base unit must be placed away from all
> electronic equipment, including PCs, stereos, TVs, and microwaves.
> What is the reasoning for this? Could the magnetic fields generated
> by the speakers in the phone cause any problems?
It will do no harm to the computer. But the other electronic equipment may interfere with the cordless phone transmission and reception.
We had a 900 mHz cordless that sat right under a TV and had no problem. But when it finally gave up the ghost we replaced it with another cordless, which turned out to be 2.4 gHz. We then found out that 2.4 gHz is much more seriously affected to the point that it was unusable. We returned it, since that was exactly where we wanted the cordless.
It is reported than 4.8 gHz is even more badly impaired by other electronic equipment.
Wes Leatherock snipped-for-privacy@aol.com snipped-for-privacy@yahoo.com
