snipped-for-privacy@sellcom.com said on that big USENET thingie:
[TELECOM Digest Editor's Note: Any phone system which can 'grab' or
> connect to a pair of wires connecting to a VOIP installation works
> okay. For example, my puny little system: If I dial '9' from any
> phone, I connect to a landline outside. If I dial '8', I connect to
> the VOIP adapter and whatever is connected to it. Granted, the VOIP
> a dapter (at least the one I have here) can only serve two lines at
> one time, but, if it mattered that much to me, I could keep stacking
> up the VOIP adapter boxes and continue the plug-ins. PAT]
Yes, but what if you had 5 or 6 POTS phones plugged into the same line, would it work, or 10 phones? I believe that is what is separating the "men from the boys" in VOIP adapters.
Regards,
Steve
Anyway, more than one (or maybe, with luck) two VOIP connections at the same time via the same broadband connection really slows things down a lot on the computer does it not? PAT]
