On May 16, 2:22 pm, Reuters News Wire wrote:
Hundreds of Indian rail passengers got more than they had bargained
> for when the driver of their train asked them to get out and push.
In Japan immediately after WW II, the infrastructure was so badly destroyed that single freight cars had to be positioned for loading by hand labor. Passengers waiting nearby applauded the workers when the car was sited.
The incident occurred in the eastern state of Bihar on Tuesday after a
> passenger pulled the train's emergency chain and it halted in a
> "neutral zone," a short length of track where there is no power in the > overhead wires.
That is actually not uncommon. Electric supply, whether by overhead wire or trackside 3rd rail, has numerous dead spots for a variety of reasons. Usually a train is long enough so that one part of it is still making contact, or a connector pole is used as Pat described below.
The train's conductor gets off the train with a long metal rod which
> he touches to a certain place under the train, and the other end of
> the rod to a place on the third rail, causing the power to
> resume. ...
This is commonly done in yards and shops where there is no 3rd rail. I wouldn't want to hold such a rod since the power supply -- enough to power a heavy train -- is enormous, plus there are nasty arcs. But it is done regularly and safely.
On subway trains, there is a "shoe" sticking out of the wheel assembly (the trucks) that makes contact with the 3rd rail. It slides along it and that powers the train. The Long Island and Metro North RRs also use this system. The power is about 600-750 V DC with very high amperage. Other systems use overhead wire of higher voltage, such as
11,000 or 25,000 V AC which is more efficient to transmit. Amtrak's NEC (with SEPTA and NJT and MARC) still runs on 25 Hz AC.
children, a favorite game we played (I was nine or ten years old) was
> entitled 'Stall the trolley bus' ...
Unfortunately, such technique was used for less benign purposes in troubled urban areas. Kids would pole down the poles of a trolleybus then board it and beat up the passengers who were from different neighborhoods or gang turfs.
The trolleybus was a nice compromise between the street flexibility of a diesel bus and the power efficiency and cleaness of electricity. Unfortunately, only a few cities still have them.
[TELECOM Digest Editor's Note: Well, Chicago got to be such a 'troubled urban area' by sometime in the 1960's. Subways were no longer safe to ride, with passengers getting robbed and raped on many occassions. They did away completely with street car and trolley busses in the late 1950's. Their claim was streetcars were too 'inflexible'; busses with rubber tires could go anywhere and trolley busses (rubber tires but with overhead wires) were too expensive to maintain. At least that's what the bigwigs in *Detroit* convinced the bigwigs at CTA to say to the public. What you need is gasoline powered motors, Detroit told CTA and other transit companies.
The excuses regards street cars were numerous also: (1) how do you do street repairs on a street which has streetcar tracks, and (2) how do firemen fight a fire with hoses spread all over the street when street cars are coming through, were two often times heard excuses. The answer to (1) is the workmen dig around or under the tracks as needed, depending on the extent and time involved. If necessary, you move the tracks. For instance, I went to visit in San Francisco in the 1960's when BART was being constructed, which was a long, involved project which involved tearing up some streets. The street car tracks were moved over as far as they could place them almost on the sidewalk while they were digging on the other side of the street. Ditto in Chicago I am told, in 1943-45 when the State Street subway was being built. Regards (2), street cars had metal 'jumps', they were called. When emergency hose was strung out in the street (i.e. firemen) the street car conductor got up right next to the large fire hoses, laid out his metal 'jump piece' on the place where the hoses crossed the tracks, drove up the little ramp and literally had the street car 'jump back down' on the track (after first alerting the passengers, of course) once the firemen's hose was out of the way. But those situations (2) were relatively rare enough as to not matter at all. And how often did firemen have to cross the entire street with hose to reach a hydrant instead of using one on 'their' side of the street? PAT]
