Re: Power Strips for Home Networks
Jun 21, 2005 0 Replies
I've accumulated so many devices on my home network (and some devices
> that are not network related as well) that power strips are an issue.
> Most of these devices have the big 'calculator charger' type of power
> supply that plugs directly into the AC outlet.
These are called "Wall Warts."
I've been looking for some type of power strip that has eight or more
> outlets that are spaced far enough apart that you can plug all of
> these things into them without overlapping each other.
One thing you can do is run several devices off of one power supply, if you have enough of them with the same voltage demands.
But I think what you want is "Dr. Ferd's Wart Remover."
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
