I'm trying to buy a cell phone WITHOUT A PLAN. I am sending it to a
> relative in another country where they will activate it.
> So far I have not found a local shopping establishment that sells > them.
> Can anyone recommend somewhere online where a cell WITHOUT A PLAN can
> be purchased? Is it even possible?
> Thanks in advance!
For post paid service the only one that I know of in the US is Cingular. You will not be eligible for any promotional rates. You will also of course pay the standard activation fee (around $35 IIRC.)
You will also likely need to pass a US credit check or if that's not possible they may ask for a substantial deposit on the account.
If that's not possible you may be relegated to using prepaid service.
There's also a newer service called Consumer Cellular
