Re: Disney Bringing Back MovieBeam Set-Top Box
Feb 15, 2006 0 Replies
In Monty Solomon
> writes: [ snip ]
>> About 10 new movies are sent each week over an unused part of the
>> broadcast TV signal using a technology called datacasting.
> ( in other words, the drive is, err, "trickle charged.. .")
> I'm troubled by this. The tv station was granted a license by the FCC
> [a] for the specific purpose of sending out a broadcast signal, that > is, a tv program.
> Ok, the world has changed, and they can take, say, 5 percent of that
> bandwidth and use it for other purposes -- in this case to slow-feed a
> separate, "store and play..." series of movies, but...
> I'd think a solid case could and should be made that this additional
> bit of effective bandwidth should be either re-bid out (after all, the
> original licensee doesn't "need it" for their licensed purpose).
> [a] once upon a time the FCC licenses had to be renewed and it was
> possible to lose them. For all intents and purposes nowadays those FCC
> licenses are permanent.
> Knowledge may be power, but communications is the key
> snipped-for-privacy@panix.com
> [to foil spammers, my address has been double rot-13 encoded]
I would not say permanent, stations do get challenged and at times lose their licenses, as LA channel 9 did after fighting it for years, and the Orange County Educational channel is under attach by a religious group that wants the license.
The only good spammer is a dead one!! Have you hunted one down today? (c) 2006 I Kill Spammers, Inc. A Rot in Hell Co.
