Re: Cellular Phone Harassment from '555-555-1212'
Apr 13, 2005 0 Replies
I have been receiving calls on my cell phone and the caller id is
> 15555551212 but there is no > Considering that 555 isn't a valid area code and xxx-555-1212 is
> Directory Assistance, why do you even bother answering that number?
And then Pat rang in with:
[TELECOM Digest Editor's Note: Because, if I understood Dale
> correctly in our phone call mid-day Tuesday, his phone just keeps
> on ringing until he _does_ answer. PAT]
I don't remember Dale mentioning that his (cellular) phone "just keeps on ringing until he does answer". And I looked at the original and full message that he sent to see if he specifically said that, at least in the post. (I do remember you mentioning that he also called and spoke with you on the phone as well). So, here is the remainder of Dale's post as it previously appeared in Telecom Digest:
I try to call back to that number and it is not a good number.
> There is no area code of 555. If any one knows what this and how
> to stop it please let me know at [address suppressed].
> Thank you very much!
Unfortunately, it does appear that the harrassing caller does "keep CALLING BACK", but that's not the same as the (cellular) phone "just keeps on ringing until he answers".
Also, considering that Dale is on a CELLULAR phone as stated in the original subject line, most of us SHOULD already know that if one doesn't answer their cellular phone within a relatively short period of time (3-5 standard ring cycles in most cases, approximately 30 seconds), the calling party is then transferred to either VOICEMAIL, or else a "subscriber not available or is out of the area" message from the serving cellular switch.
Also, unfortuantely, as Pat has stated several times in the past regarding Caller-ID and Privacy options from SBC, the serving telephone company on the called party's end doesn't really "block" incoming calls from KNOWN BOGUS area and/or office codes, or known bogus "formats" of same codes.
- Anthony
