Re: Can I Substitute a NiMH Battery for NiCd in a Cordless Phone?
Apr 18, 2005 0 Replies
I recently bought a cordless ph> "To reduce the risk of fire, use only 3.6V 850mAh Nickel Cadmium
> (Ni-Cad) cordless telephone replacement battery pack."
> I've heard about the dreaded "memory effect" with NiCd batteries, so
> I'm interested in replacing it with a NiMH one. Someone who is
> selling a 3.6V 1000mAH NiMH battery on Ebay claims it works with my
> phone, but will it really be safe? Wouldn't want to install a NiMH
> battery and have the house burn down.
> [TELECOM Digest Editor's Note: 3.6 at 850 is _close enough_ to 3.6 at
> 1000 that I think it should work. The difficulty with swapping
> batteries around randomly however is not so much that your house would
> burn down as it is that differences in those batteries could possibly
> cause some slow degredation on your electronics unit and cause it to
> fry out prematurely. Your voltage (3.6) is critical; you want to avoid
> increasing _low voltages_ very much. A device which calls for 3.6
> should pretty much be confined to 3.6. You can play around with the
> amperage a bit however; 1000 will work fine with something rated for
> 850. But make certain the battery contacts line up correctly and do
> not cause a short circuit accidentally. It would be a shame to waste
> that new battery as soon as you got it. PAT]
Many places sell batteries for cordless phones and have cross-reference guides by model number, also by size, shape, voltage and type of connector used.
The battery packages have a list of cordless phone model numbers they are designed for. Wal-Mart carries a pretty extensive line of cordless phone batteries at competitive prices, probably not much more than the shipping costs charged by an eBay seller.. The ones I have seen in Wal-Mart are GE/Sanyo brand. I have also seen cordless phone batteries in many other places; Walgreen's for one, I believe.
Make sure the connector matches.
Wes Leatherock snipped-for-privacy@aol.com
