Need help with LSDI 4000 Line Sharing Device
Feb 21, 2006 2 Replies
Just bought a LSDI series 4000 Line shaing device on ebay.. Works great ! Will send fax immediately to computer for fax program on first ring. Problem is that I no longer can get the caller ID on any lines in house if I use it. Called Manufacturer and they were upset that I bought from Ebay and said it would be a minimum $50 to talk to a tech. Anybody have one of these or can tell me how to set up for caller ID? Manufacturer insinuated that you could...but meter would be running if we talked about how. Thanks for any help... Bob
10years to late but this info may help
Model 4000/8000 Programming: CNG OFF
LONG 1 WAIT FOR TONE
000000# WAIT FOR TONE LONG 6 WAIT FOR TONE # WAIT FOR TONE LONG 7 WAIT FOR TONE 0200 WAIT FOR TONE HANG UP
CNG ON
000000# WAIT FOR TONE LONG 6 WAIT FOR TONE 8 HANG UP HANG UP
ACCEPT DISTINCTIVE RINGING ? DEVICE 2
000000# WAIT FOR TONE LONG 0 WAIT FOR TONE 1201 WAIT FOR TONE HANG UP
ACCEPT DISTINCTIVE RINGING ? DEVICE 3
000000# WAIT FOR TONE LONG 0 WAIT FOR TONE 1231 WAIT FOR TONE HANG UP
TELCO ANSWERING SERVICE (Note: Telco answering service works in passive mode only. Once the TC4000 is programmed for passive mode, no remote programming is possible.)
000000# WAIT FOR TONE LONG 6 WAIT FOR TONE HANG UP
CALL DISPLAY (Note: Fax rings the phone, the caller ID is displayed, and then call goes to the Fax).
000000# WAIT FOR TONE LONG 0 WAIT FOR TONE 1002 WAIT FOR TONE LONG # WAIT FOR TONE 4514 WAIT FOR TONE LONG 8 WAIT FOR TONE 4000 WAIT FOR TONE HANG UP
CALL DISPLAY PROGRAMMING ON 4000P LONG 1 WAIT FOR TONE
000000# WAIT FOR TONE LONG 0 WAIT FOR TONE 3002 WAIT FOR TONE LONG # WAIT FOR TONE 4514 HANG UP
CHANGE PORT 1 ANSWERING TO 20 RINGS
000000# WAIT FOR TONE LONG 5 WAIT FOR TONE ***0 WAIT FOR TONE HANG UP
CHANGE PORT 2 ANSWERING TO 10 RINGS
000000# WAIT FOR TONE LONG 5 WAIT FOR TONE 0000 WAIT FOR TONE HANG UP
CHANGING PORT ADDRESSES (EXAMPLE: FROM 11 TO 21, ETC.) LONG 1 WAIT FOR TONE
000000# WAIT FOR TONE LONG 4 WAIT FOR TONE OLD ADDRESS (e.g., 11 for PORT1) WAIT FOR TONE NEW ADDRESS (e.g., 21# for PORT1) WAIT FOR TONE LONG 4 WAIT FOR TONE NEXT OLD AND NEW ADDRESS OR HANG UP
CHANGING PORT ANSWERING ASSIGNMENT
000000# WAIT FOR TONE LONG 3 WAIT FOR TONE 1419 (FOR PORT 1) WAIT FOR TONE OR 2409 (FOR PORT 2) WAIT FOR TONE OR 3409 (FOR PORT 3) WAIT FOR TONE OR 4409 (FOR PORT 4) WAIT FOR TONE HANG UP
INTERCOM MODE (NOTE: TO ACCESS PORTS, SIMPLY DIAL THE PORT ADDESS)
000000# WAIT FOR TONE LONG 6 WAIT FOR TONE 9 WAIT FOR TONE HANG UP
DELAY IN ANSWERING (Note: This programming is ideal when there are two phones each in separate location. One phone is connected to the wall plate and another connected to the 4000 Port 1. When a call come in, phone connected to the wall plate will ring first so many numbers of times depending on the programming before the switch picks up the call.)
000000# WAIT FOR TONE LONG 6 WAIT FOR TONE LONG 4 WAIT FOR TONE (NOTE: IF DEVICE HAS CNG ON AND WANT TO ENABLE CNG OFF.) LONG 7 WAIT FOR TONE 200 WAIT FOR TONE LONG # WAIT FOR TONE 5034 (APPROX. 15.5 SECS ~ 4 +/- RINGS) WAIT FOR TONE OR 5044 (APPROX. 20.5 SECS ~ 5 +/- RINGS) WAIT FOR TONE OR 5054 (APPROX. 25.5 SECS ~ 6 +/- RINGS) WAIT FOR TONE HANG UP
ENABLE TOLL RESTRICTION (NOTE: THIS PREVENTS ANY 1-XXX-XXX-XXX CALLS. TO OVERRIDE RESTRICTION, DIAL 796, THEN 1-XXX-XXX-XXX).
000000# WAIT FOR TONE LONG * WAIT FOR TONE 000000# WAIT FOR TONE LONG 0 WAIT FOR TONE 1951 WAIT FOR TONE HANG UP
