What FireWall to run?
May 16, 2005 6 Replies
Duane Arnold
Italy Anonymous Remailer You can use IPsec in conjunction with XP's PFW solution and you can stop all the inbound and outbound traffic you want with IPsec. :)
What FireWall to run? open original image
I'm sure that this has been beaten to death on this group but.....
I've run the free version of ZoneAlarm for more years than I can remember. The last build however has played hell with both PC's here. I run Mozilla suite, XP-Home and I have not loaded SP-2 on either PC's. I constantly have to shut down ZoneAlarm in order to access the Web. I've recently un-installed it and am currently running the last free version of Kerio
2.1.5 which I really do not have much knowledge of.
Any suggestions other than ZoneAlarm for a free firewall that will handle both outgoing and incoming traffic? I did try the latest build of Kerio and it slowed my internet down by approx. 60%.
Thanks for any guidance given.
Italy Anonymous Remailer wrote in news: snipped-for-privacy@anonymous.poster:
Duane :)
If it cause that much drain on your system then you're going to have problems with anything that works.
Get a simple NAT Router.
Windows XP built-in firewall plus an anti-spyware application (MS' AntiSpyware works great)
"Wayne" wrote in news:d68i6l$nrr$ snipped-for-privacy@domitilla.aioe.org:
A friend of mine says the built-in XP firewall fails the basic security leak test:
which I found highly alarming!
Kind regards
-- encoderX -
The leaktest is designed to test 'internal extrusion' as opposed to 'external intrusion'^1 -- the XP 'firewall' or ICF is designed^2 to monitor external intrusion. You would need a software internal extrusion defense such as ZoneAlarm to pass the leaktest.
MS AntiSpyware^3 is a spyware detector and remover, it isn't an internal extrusion defense either and also would not help with the leaktest.
^1
What's Wrong With Some Firewalls? ^2
Windows Firewall ^3
Windows AntiSpyware (Beta): Overview
