Watchguard is losing routing information after Reboot
Aug 25, 2005 1 Replies
Hey everyone,
recently I experienced problems with my old Firebox II. From time to time it loses routes after a normal reboot. A look into my routing-config tells, that everything is alright, although the specific route doesn't exist in the status-monitor. When I add the network route once more, save it to the device and reboot it, I sometimes loose another important route. I have only 50 routing entries on the device. This is not much from my point of view.
Any suggestions the device loses part of its routes after the reboot ??? Has anyone experienced this before
Thanks for your help so far.
7th_wave
I have a FB II here in our office, but I've not seen anything like you describe -sorry I can't help.
What firmware are you running?
