Stateful Packet Inspection and STUN
Sep 26, 2010 0 Replies
If a computer on the inside initiates a STUN session, does that suggest it has been compromised?
If I'm running SPI (ip inspect myfw out) on my router with PAT (ip nat inside source list 101 interface FastEthernet0/0 overload), will that block incoming packets that target the NATed host's global IP address and port?
Does SPI require a correct match of sequence number for reply packets or simply IP address and port number? IOS: C2600-IK9O3S-M, Version 12.3(26)
