Port forwarding from Internet to lan webserver
Nov 11, 2006 2 Replies
Hello,
I try to access my webserver in lan from internet. I try to forwarding internet 81 port from my server to my lan pc port 80, so in that way i could access my lan webserver from internet in this way: http://my_server_ip:81/ I have debian installed in my server and try to config iptables in this way:
eth0 - internet eth1 - lan
iptables -t nat -A PREROUTING -i eth0 -p tcp --sport 81 j DNAT
--to-destination 192.168.1.2:80
i try some other configuraion witch i found by google, but no one worked.
Could you help me to solve this problem?
Yeah, you should get something that's less complicated.
Duane :)
[TXT] NAT-HOWTO.txt 17-Oct-2004 14:34 25K
So you will take packets that come from some host on the internet that are _sourced_from_ port 81, and send them on. Sorry - not going to work. Try
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 81 j DNAT
The web site above will help. Last I checked, it had seven different HOWTOs in several languages. By the way, "it doesn't work" is a rather useless description, that tells nothing. You have to look, and report what is in the logs and error messages. Did the computer catch fire? That might tell someone what you did wrong.
Old guy
