NAt trouble (i think)
Dec 22, 2005 0 Replies
Hello, I'm a PIX newbie and am fumbling around with some of my config. I'm trying to get SQL queries from a machine on the internal interface over a DMZ to a server at the other end of the DMZ.
From the PIX terminal I am able to ping the SQL box, but I am not able
to get any traffic across from the machine on the internal interface. I thought my config was pretty simple, but perhaps too simple since it does not work.... Im wondering if i need a special ACL or a nat 0 statement or something but i dont really know what i am supposed to do with those! ... : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 auto interface ethernet2 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 nameif ethernet2 Gozer_DMZ security30 enable password hostname domain-name fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.10.2 isa access-list 101 permit tcp any interface outside eq https access-list 101 permit tcp any interface outside eq www access-list Gozer_DMZ_Access permit icmp any host 172.18.15.10 echo access-list Gozer_DMZ_Access permit tcp host 172.18.15.5 eq 1433 host
172.18.15.10 pager lines 24 mtu outside 1500 mtu inside 1500 mtu Gozer_DMZ 1500 ip address outside 10.10.10.1 255.255.255.0 ip address inside 192.168.10.1 255.255.255.0 ip address Gozer_DMZ 172.18.15.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.0.0 255.255.0.0 inside pdm logging informational 100 pdm history enable arp timeout 14400 static (inside,outside) tcp interface https isa https netmask
255.255.255.255 0 0 static (inside,outside) tcp interface www isa www netmask
255.255.255.255 0 0 static (inside,Gozer_DMZ) 172.18.15.10 isa netmask 255.255.255.255 0 0 access-group 101 in interface outside access-group Gozer_DMZ_Access in interface Gozer_DMZ route outside 0.0.0.0 0.0.0.0 10.10.10.1 0 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.10.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps tftp-server inside 192.168.10.254 / floodguard enable telnet timeout 5 ssh 192.168.0.0 255.255.0.0 inside ssh timeout 30 console timeout 0 terminal width 80 banner exec ***** Authorized Use ONLY : end gzr00#
