iptables port forwarding not working
Sep 14, 2005 1 Replies
hi-
following a helpful gentoo guide on iptables I got it to replace my netgear router, but I've not been able to get port forwarding working. here are my defs:
iptables -F iptables -t nat -F iptables -P INPUT ACCEPT iptables -P OUTPUT ACCEPT iptables -P FORWARD DROP
export LAN=eth0 export WAN=eth1
iptables -I INPUT 1 -i ${LAN} -j ACCEPT iptables -I INPUT 1 -i lo -j ACCEPT
iptables -A INPUT -p UDP --dport bootps -i ! ${LAN} -j REJECT iptables -A INPUT -p UDP --dport domain -i ! ${LAN} -j REJECT iptables -A INPUT -p TCP --dport ssh -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport www -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport https -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport smtp -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport auth -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport imaps -i ${WAN} -j ACCEPT iptables -A INPUT -p TCP --dport ssmtp -i ${WAN} -j ACCEPT
iptables -A INPUT -p TCP -i ${LAN} -d 0/0 --dport 0:1023 -j DROP iptables -A INPUT -p UDP -i ${LAN} -d 0/0 --dport 0:1023 -j DROP iptables -I FORWARD -i ${LAN} -d 192.168.0.0/255.255.0.0 -j DROP iptables -A FORWARD -i ${LAN} -s 192.168.0.0/255.255.0.0 -j ACCEPT iptables -A FORWARD -i ${WAN} -d 192.168.0.0/255.255.0.0 -j ACCEPT iptables -t nat -A POSTROUTING -o ${WAN} -j MASQUERADE
iptables -t nat -A PREROUTING -p tcp --dport 902 -i ${WAN} -j DNAT --to
192.168.0.201 iptables -t nat -A PREROUTING -p tcp --dport 3389 -i ${WAN} -j DNAT
--to 192.168.0.201 iptables -t nat -A PREROUTING -p tcp --dport 7004 -i ${WAN} -j DNAT
--to 192.168.0.201 iptables -t nat -A PREROUTING -p tcp --dport 6346 -i ${WAN} -j DNAT
--to 192.168.0.201 iptables -t nat -A PREROUTING -p tcp --dport 6883 -i ${WAN} -j DNAT
--to 192.168.0.201
echo 1 > /proc/sys/net/ipv4/ip_forward for f in /proc/sys/net/ipv4/conf/*/rp_filter ; do echo 1 > $f; done /etc/init.d/iptables save
Also, when building kernel 2.4.22, I didn't find the option for "IP range match support" within IP: Networking Options -> IP: Netfilter Configuration ---> IP tables support, so I just skipped it. Did I do bad?
What's off?
Bill
First off sorry for the late reply.
Second if you already have the answer then good.
This is why it's not working. You are dropping everything that is to be forwarded. didn't see any accept forward rules in your tables.
