impossible IP packet
Mar 18, 2005 2 Replies
impossible IP packet open original image
Hi, we have a couple of servers on our network that are sending UDP packets port 137 and 138, NetBIOS, to themselves. The source IP and destination IP is the same and they show up in our IDS as 'impossible ip packets', I'm wondering if you think something on these servers might have been miss configured at one time. They're Windows 2003 servers, one is our PDC and the other is a DHCP server. Thank you for any help you may give.
Rossella Mariotti-Jones
Network Analyst, CCNA
Chemeketa Community College / IT
T 503 589 7775
F 503 399 4898
E snipped-for-privacy@chemeketa.edu
Hello
Looks like LAND attacks :
Some Win2003 hosts are known to become unresponsive for some seconds upond reception of these LAND attacks.
Configure your external firewalls to drop packets coming from a range that is behind your firewall (spoofed packets), and see if activity continues. If not, that means these packets are not generated by your servers.
HTH
Maxime Ducharme Programmeur / Spécialiste en sécurité réseau
Another important point
A server that sends a packet to itself wont use network media (i.e. cable) to send the packet since it is local.
If the IDS isnt on the same machine, it should not see these packets, so these are likely to come from somewhere else.
It can be Internet, or another server. Try to capture the MAC address and see if it is your router or a server.
Good luck :)
