Firewall Blocking ActiveX
Jul 31, 2006 9 Replies
Jump to replies (9)
Folks,
I have a bunch of alarm reports from my NetScreen firewall that have me perplexed. They look like:
ActiveX control blocked! From OUTSIDEIP:80 to MYIP:2264 ActiveX control blocked! From OUTSIDEIP:80 to MYIP:2263 ActiveX control blocked! From OUTSIDEIP:80 to MYIP:2262 ActiveX control blocked! From OUTSIDEIP:80 to MYIP:2258 UDP flood! From DIFFERENT_OUTSIDE_IP:53 to MYIP:2256
and then some others originating from inside my network:
UDP flood! From MYIP:137 to OUTSIDEIP:137 UDP flood! From MYIP:137 to DIFFERENT_OUTSIDEIP:137
The port 137 traffic I assume is netbios/reverse ns activity (either surfing onto windows servers from the my server (MYIP), or web activity to our server (which is win 2003)). If that's the case, should I allow port 137 originating from inside my network to help with logging?
Searching the web for the port ranges for the blocked ActiveX control has turned up no info. Could that be from surfing the web from our server as well? I should mention that a reverse NS lookup on the remote IPs doesn't turn up any domains that looks familiar (beyond regular ISP domains (comcast, etc).
Thanks, Patrick
You should not allow any NetBIOS traffic to transit the perimeter. Allowing it won't help with logging either, rather install a sniffer and check your server's configuration.
Definitely.
OK, that's rather strange.
In the meanwhile I'm asking what an ActiveX filter rule should even look like, as there's no significant difference between invoking an ActiveX control and invoking any general plugin, including the browser's internal viewers.
Good idea, I'll set one up.
I'm not sure why anything is being flagged as an ActiveX control. I don't believe I put anything discriminating in the rules. I'll contact the vendor of the firewall and post a follow up if I get a response.
Thanks for your help Sebastian.
Patrick
Maybe because ActiveX lacks a security concept and therefore is very dangerous to send through the net?
Yours, VB.
s/security/working security/
Anyway, there is no significant difference between invoking a local ActiveX control and emebedding any general multimedia object. Remotely loaded ActiveX objects could only be detected by eventually unpacking a CAB file and then either the .ocx file extension or by analyzing the PE executable for certain COM imports.
It totally lacks a security concept. "Do you trust, because there is no security concept" is none, sorry.
That's wrong, at least for Flash, PDF, Java Applets and nearly anything else beside WMV.
No.
Usually, they're just embedded as an object in HTML.
Yours, VB.
It would be a security concept if there'd actually be some confidence to support the trust. And if one could actually disable ActiveX at all.
Huh? Some little example:
Now is that just an image supposed to be displayed by either the browser itself or a plugin? Or is it an invocation of an ActiveX control "Image" with Interface "JPEG", supposed to load and probablby display this image?
Just like any other general multimedia object.
Actually, at most it would be a b0rken security concept at all, if one wants to see something like that as a security concept.
But: maybe for some people, having no car is a kind of vehicle, too, because this means, you're pedestrian ;-)
I don't want to argue that. Maybe this is a misunderstanding.
But they are no general multimedia objects.
Yours, VB.
I am currently running Windows XP SP2 (fully patched) and use a Bitdefender, Spywareblaster, and Ad-Aware for antivirus/antispyware. My single XP box at home is connected to my broadband internet connection via a D-Link 604 (latest firmware) router. I use OpenSSH to tunnel home from work and use Windows Remote Desktop tunneled through SSH to remote-control my machine from work.
I have had my little D-Link router for about 2 years now and I have never had a problem. The only open port I allow access to is the one through which I use SSH, and even that I have only allow to trigger when accessed via the IP I use from work. My router does not reply to any pings, block Port 113 by default, and allows shows up as fully stealthed by every scanner with which I ever test it.
No... I don't run any software firewall and I have disabled Windows SP2's built-in "firewall."
I don't use IE or Outlook Express and I am not random "click on this banner" kind of person.
In mid-2006, I now ask, am I protected enough? I think I am and the proof is I've never had any problems. Discussion?
Thank you.
I think, we'll not come together here, Sebastian.
Yours, VB.
