Fake " AntiVia AV " virus Alert
Feb 10, 2011 1 Replies
AntiVira Av is another malware that may lead you into thinking that it is legitimate program called Avira AntiVir. Don=92t fall into this trick because you will only let malicious intruder inside your machine which additionally will do its best in order to make you purchase its =91license=92. Classically, there is no =91license=92 existing and, just li= ke the earlier released AVG Antivirus 2011 scam, it will let more dangerous cyber threats instead of cleaning the PC. AntiviraAv hails from the same family which should be blamed for creating Antivirus.net malware which has infected numerous users. All these unnoticeable intrusions can be avoided but only if you use the =91full=92 version of anti-spyware and anti-virus because they provide real time protection.
This virus is infecting systems over internet and across networks. Neware of the fake AntiVia AV scam tool. if you`r infected by this virus, run an anti malware program or do a manual remove to get rid of this virus.
Happy virus free computing
AntiVia AV virus manual removal instructions
Removal tools (or instructions for manual removal) are no solution to an infection, particularly not with malware that may download more malware or may give an attacker remote access. One can never be sure what else was modified on the system and thus can never be certain that the malware was removed entirely.
cu
59cobalt
