Enabling remote ssh access
Mar 28, 2005 3 Replies
Most relevant reply
Troy Piggins
Shouldn't that be: iptables -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT Note -------+ (not ssh_config) V /etc/ssh/sshd_config add these lines : PermitRootLogin no AllowUsers troy If you don't have strong passwords, you should look at public key auth too.
I am working on a Linux network that was set-up by someone else and I need help enabling remote SSH access.
Here's what I've done so far, but to no avail.
iptables -A INPUT -p udp --sport 22 -j ACCEPT
and I've added the following to the hosts.allow file:
ALL:ALL sshd:ALL
Shouldn't that be:
Also Take care abut outgoing packets from our machine since tcp is a two way protocol. Esle if default policy of output chain is to drop, then connection won't respond
I think the -m tcp it's not needed. And he also have to use the RELATED and ESTABLISHED rules for the outgoing traffic. Something like: iptables -A OUTPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
Regards.
