basic pix 7.0(1) icmp question
Jul 18, 2007 5 Replies
Jump to replies (5)
this should not be a challange...
i want to deny icmp to the outside interface:
access-list acl_outside; 4 elements access-list acl_outside line 1 extended permit tcp any host 1.2.3.4 eq ftp (hitcnt=3531) access-list acl_outside line 2 extended permit tcp any host 1.2.3.4 eq www (hitcnt=36336) access-list acl_outside line 3 extended permit tcp any host 1.2.3.4 eq 81 (hitcnt=2130) access-list acl_outside line 4 extended deny icmp any interface outside (hitcnt=0)
my ping to the outside interface is still being answered... what's going on?
PS: I would like to allow ping to inside host, and would add:
access-list acl_outside extended permit icmp any host 1.2.3.4
correct?
found the problem: icmp deny any outside
Doesn't this forbid any icmp message?
like: "FRAGMENTATION_NEEDED_BUT_DF_SET", "Source_QUENCH" (ok, very seldom these days), "TIME_EXCEEDED", "PARAMETER PROBLEM", "DESTINATION UNREACHABLE".
But you are probably sure, that you want to do a blind network flight.
Cheers, Jens
yes it does, but customer wants it that way ...
Make sure to have a small note signed, that he is aware of the fact, that he will have problems in the future.
Cheers, Jens
Yes, but only to the PIX itself. The 'icmp' command only controls the ICMP messages that the PIX handles on its own behalf; for ICMP messages headed to hosts "inside", access-group has control.
