Hi all,
I have a Cisco 857W as router (with 1 fixed public address). NAT is in use and behind it there are some servers (mail, www, dns).
Everything works fine except my voip box (Linksys/SPA2100-3.3.7). It is able to register with VoIP provider (BroadVoice). It can also dial, but nothing is heard on my side (so I suspect a problem with NAT on the rtp side.
I did a debug ip nat and found something strange (look at second line, there is a port with 0 - zero value in the inside global):
Pro Inside global Inside local Outside local Outside global udp AAA.BBB.CCC.DDD:1042 10.10.10.128:5060 147.135.4.129:5060
147.135.4.129:5060 udp AAA.BBB.CCC.DDD:0 10.10.10.128:16426 147.135.4.247:38192
147.135.4.247:38192 tcp AAA.BBB.CCC.DDD:60011 10.10.10.128:60011 147.135.0.32:8080
147.135.0.32:8080 udp AAA.BBB.CCC.DDD:60203 10.10.10.128:60203 147.135.0.6:53
147.135.0.6:53 udp AAA.BBB.CCC.DDD:60203 10.10.10.128:60203 147.135.8.6:53
147.135.8.6:53 udp AAA.BBB.CCC.DDD:60203 10.10.10.128:60203 195.110.128.1:53
195.110.128.1:53 icmp AAA.BBB.CCC.DDD:28976 10.10.10.128:2188210480 147.135.8.6:2188210312
147.135.8.6:28976 icmp AAA.BBB.CCC.DDD:28976 10.10.10.128:2188210480 195.110.128.1:2188210312
195.110.128.1:28976
Did a capture with Wireshark (on the inside side) and found many RTP packets going out but none coming in.
I am very disappointed since before the Cisco 857W I was using a very basic Home router and the voip box was working well (behind a NAT).
Please help !!!
Is this a configuration problem or a bug on the IOS sw?
TIA,
Mike
