Voice thru vpn volume goes up and down constantly HELP
Jan 18, 2007 1 Replies
Voice thru vpn volume goes up and down constantly HELP open original image
I have a hub and spoke architecture in place with 1 main hub and 4 remote offices connected with VPNs and all are CISCO PIX515e's. The problem I have is with 3 of those remotes reporting the volume level goes up and down and gets so low nothing can be heard at all. This happens both internally and externally.
I am not using VLANs but rather the phone communicates a TOS of 5 or DSCP of 46 on ports 6000 - 6062 . QOS is enabled for RTP, UDP and DSCP on those same ports.
And just in case you were wondering, YES the 1 location that works fine has been duplicated to all the others as well. (of course the interface IPs for the VLANs being different)
ANY IDEAS?...
You may want to investigate Cisco's Troubleshoot Voice Quality Issues:
Sincerely,
Brad Reese
2007 Cisco Salary Rates
