vlans on 2948
Apr 04, 2006 2 Replies
i have two incoming networks from my isp to my 2948G-L3
i would like to have separate vlans for each network, and have each with their own default gateway. how can i achieve this?
Cheers,
-Todd
I've forgotten the limitations of the 2948G-L3, but I think you should be able to use a route-map for this.
Hi Todd,
Nice cheap/fast multi-port Layer 2 box that can do a bit of layer
3......;-) We stll have a few in use at work.
I have not played much with CatOS so I can't answer for that environment sorry. So assuming your 2948G-L3 is runnning IOS, then you need to configure a BVI for each VLAN, and put the required ports into the appropriate Bridge-group. Then you would need to set up route-maps for each VLAN.
Cheers...............pk.
