Standby ASA stops doing ospf after upgrade
May 30, 2007 0 Replies
after upgrading fover pair to asa722-22-k8.bin on reboot i see this on standby. no ospf routes in table
sfo2-asa-01> . Detected an Active mate Beginning configuration replication from mate. DHCPRA: Deleting last server while DHCPRA is running. No relaying will be done. Device Manager image set, but unable toAllowing OSPF process to run for a while to complete config sync. nAllowing OSPF process to run for a whifle to complete config syinc. d disk0:/asdm521-54.bin nat 0 0.0.0.0 will be identity translated for outbound Allowing OSPF process to run for a while to complete config sync. Allowing OSPF process to run for a while to complete config sync. Allowing OSPF process to run for a while to complete config sync. Allowing OSPF process to run for a while to complete config sync. INFO: Only classful networks will be redistributed End configuration replication from mate. sfo2-asa-01> en
running debug ospf on the standby i see
OSPF: Input packet ignored. OSPF: Input packet ignored
