Routing problem
Apr 30, 2006 7 Replies
Jump to replies (7)
I have added a router to my network (10.10.0.0/16). This router has an interface into 10.10 and another one in 192.168. All users in 10.10 use a PIX 515 to access to Internet. PIX has an interface in 10.10. network. Users from 192. 168 can access resources in 10.10 network but cannot go to Internet.
here is the info:
user:
192.168.1.99 DG: 192.168.1.254 Router
Router: No Nat, no Global DG: 10.10.6.254 Inside Interface of PIX
Does anyone know how to solve this problem and give users on 192.168 access to Internet thru PIX box.
Thanks for any help in advance.Rob
Is the PIX NATing for the 192.168.1.0 subnet? Does it have a route back to the router for it as well?
Steve
On 01.05.2006 01:24 Rob wrote
You have to tell the PIX to route 192.168.1.0/24 via 10.10.6.254
On PIX I have: nat (inside) 1 0.0.0.0 0.0.0.0 0 0 Does it mean that I already have nating for 192.168 network. (Inside PIX is
10.10.) Rob
On 01.05.2006 15:23 Rob wrote
with 0/0 (aka 0.0.0.0 0.0.0.0 0) you already nat *everything* from inside. Hence also 192.168.1.0/24.
Of course you should also set default on the router to point to the
10.10.0.0/16 address of the pix.
Arnold
yes, I have the default route on Router to point to the PIX inside interface. ip route 0.0.0.0 0.0.0.0 10.10.6.254 But stil doesnt work, I even cannot ping PIX inside from 192.168 network, I am able to ping all other machines inside 10.10. network from 192.168. Any idea? Rob
Show us the routing table on the PIX. If your 192 net can ping 10 stuff, then it sounds like the pix doesnt know how to get back to the
192.
See Arnold's comment above. Rob wrote:
