Pix 506 crc errors
Feb 15, 2005 0 Replies
Hi, I have a pix 506 that's giving me crc and input errors (an avg of 50 errors/hour) It keeps rebooting itself every 24 hrs. I have put in a new pix, changed the cabling(crossover cables to a switch), change the speed from half duplex to full and at one point auto. Placed a hub then a switch in between. Swapped the cables between the inside and outside interfaces. I have also checked the crypto map and management access inside as well as making sure the sysopt command is in place. Nothing indicates why we see intermittent crashes. Nothing has changed configuration wise.I have thrown everthing at this and am at a loss.
Any suggestions?
--Sydonna
