pix 5.3(2) dns problem
Sep 02, 2005 1 Replies
pix 5.3(2) dns problem open original image
I am having a problem with allowing mail (pop3) through pix . I have access-lists allowing pop3,udp and tcp dns. The thing is when I allow all ip, mail is working. And when I allow only pop3 and dns, it's not. It says in the log that no translation group is found...
I am little bit confused, am I having a problems because of the older sw version?
Thanks, Ivana
Not sure which direction you are talking about: Is it from your LAN to an Internet POP3 server or are you hosting a POP3 server on your LAN and Internet users need to access it.
Have you tried telnetting to a mail server on port 110 - using the IP address of the mail server rather than its name.
What about SMTP as well?
Regards,
Nick Ersdown
