phase 1 isakmp failing
Nov 04, 2008 1 Replies
Can someone please assist?
Thanks
*Nov 4 20:56:26.221: ISAKMP:(0:0:N/A:0):purging node 2095033855
*Nov 4 20:56:26.221: ISAKMP:(0:0:N/A:0):purging node 2077560282
*Nov 4 20:56:36.213: IPSEC(key_engine): request timer fired: count =
2, (identity) local= 119.111.xxx.xxx, remote= 203.200.xxx.xxx, local_proxy= 10.10.0.0/255.255.240.0/0/0 (type=4), remote_proxy= 10.126.1.14/255.255.255.255/0/0 (type=1)
*Nov 4 20:56:36.213: ISAKMP: received ke message (3/1)
*Nov 4 20:56:36.213: ISAKMP:(0:0:N/A:0):peer does not do paranoid keepalives.
*Nov 4 20:56:36.213: ISAKMP:(0:0:N/A:0):deleting SA reason "P1 delete notify (in)" state (I) MM_NO_STATE (peer 203.200.xxx.xxx)
*Nov 4 20:56:36.213: IPSEC(sa_request): , (key eng. msg.) OUTBOUND local= 119.111.xxx.xxx, remote=
203.200.xxx.xxx, local_proxy= 10.10.0.0/255.255.240.0/0/0 (type=4), remote_proxy= 10.126.1.14/255.255.255.255/0/0 (type=1), protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel), lifedur= 3600s and 4608000kb, spi= 0x55BDE669(1438508649), conn_id= 0, keysize= 0, flags= 0x400A
*Nov 4 20:56:36.217: ISAKMP: received ke message (1/1)
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): SA request profile is (NULL)
*Nov 4 20:56:36.217: ISAKMP: Created a peer struct for
203.200.xxx.xxx, peer port 500
Nov 4 20:56:36.217: ISAKMP: New peer created peer = 0x43AA9DD4 peer_handle = 0x8000005C
*Nov 4 20:56:36.217: ISAKMP: Locking peer struct 0x43AA9DD4, IKE refcount 1 for isakmp_initiator
Nov 4 20:56:36.217: ISAKMP: local port 500, remote port 500
*Nov 4 20:56:36.217: ISAKMP: set new node 0 to QM_IDLE
Nov 4 20:56:36.217: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 4370D574
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0):Can not start Aggressive mode, trying Main mode.
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0):Looking for a matching key for 203.200.xxx.xxx in default
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): : success
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 203.200.xxx.xxx
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-07 ID
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-03 ID
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): constructed NAT-T vendor-02 ID
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0):Old State = IKE_READY New State = IKE_I_MM1
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): beginning Main Mode exchange
*Nov 4 20:56:36.217: ISAKMP:(0:0:N/A:0): sending packet to
203.200.xxx.xxx my_port 500 peer_port 500 (I) MM_NO_STATE
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):deleting SA reason "P1 delete notify (in)" state (I) MM_NO_STATE (peer 203.200.xxx.xxx)
*Nov 4 20:56:36.221: ISAKMP: Unlocking IKE struct 0x43711B80 for isadb_mark_sa_deleted(), count 0
Nov 4 20:56:36.221: ISAKMP: Deleting peer node by peer_reap for
203.200.xxx.xxx: 43711B80
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):deleting node 1146726567 error FALSE reason "IKE deleted"
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):deleting node -2133103557 error FALSE reason "IKE deleted"
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):Old State = IKE_I_MM1 New State = IKE_DEST_SA
*Nov 4 20:56:36.221: ISAKMP:(0:0:N/A:0):purging SA., sa=43716E60, delme=43716E60
*Nov 4 20:56:36.221: IPSEC(key_engine): got a queue event with 1 kei messages
Nov 4 20:56:46.221: ISAKMP:(0:0:N/A:0): retransmitting phase 1 MM_NO_STATE...
*Nov 4 20:56:46.221: ISAKMP (0:0): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Nov 4 20:56:46.221: ISAKMP:(0:0:N/A:0): sending packet to
*Nov 4 20:56:56.221: ISAKMP:(0:0:N/A:0): retransmitting phase 1 MM_NO_STATE...
*Nov 4 20:56:56.221: ISAKMP (0:0): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Nov 4 20:56:56.221: ISAKMP:(0:0:N/A:0): sending packet to
*Nov 4 20:57:06.213: IPSEC(key_engine): request timer fired: count =
1, (identity) local= 119.111.xxx.xxx, remote= 203.200.xxx.xxx, local_proxy= 10.10.0.0/255.255.240.0/0/0 (type=4), remote_proxy= 10.126.1.14/255.255.255.255/0/0 (type=1)
*Nov 4 20:57:06.213: IPSEC(sa_request): , (key eng. msg.) OUTBOUND local= 119.111.xxx.xxx, remote=
203.200.xxx.xxx, local_proxy= 10.10.0.0/255.255.240.0/0/0 (type=4), remote_proxy= 10.126.1.14/255.255.255.255/0/0 (type=1), protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel), lifedur= 3600s and 4608000kb, spi= 0x712A5AF7(1898601207), conn_id= 0, keysize= 0, flags= 0x400A
*Nov 4 20:57:06.213: ISAKMP: received ke message (1/1)
*Nov 4 20:57:06.213: ISAKMP: set new node 0 to QM_IDLE
Nov 4 20:57:06.213: ISAKMP:(0:0:N/A:0):SA is still budding. Attached new ipsec request to it. (local 119.111.xxx.xxx, remote
203.200.xxx.xxx)
*Nov 4 20:57:06.221: ISAKMP:(0:0:N/A:0): retransmitting phase 1 MM_NO_STATE...
*Nov 4 20:57:06.221: ISAKMP (0:0): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Nov 4 20:57:06.221: ISAKMP:(0:0:N/A:0): sending packet to
