NHPR behaves unexpectedly
Oct 10, 2008 7 Replies
Jump to replies (7)
I set up a DMVPN with NHRP between two networks connected to the UMTS net (my spokes) and one connected via DSL (my hub).
Everything seems to be fine, but when I traceroute from one spoke to the other, I find that they communicate via the hub, and not - as I expect - directly with each other.
The "show ip nhrp" output tells me, that the spokes learned the other spoke=B4s outside IP address so they ought to be able to connect directly to each other without the hub in between.
I attach the "show ip nhrp" output from one of my spokes, the "traceroute" output of the same spoke an my configurations.
I use eigrp for routing.
Maybe someone has an idea?
Thank=B4s a lot. Mathias
Spoke Router:
RT_UMTS#sho ip nhrp
172.16.1.10/32 via 172.16.1.10, Tunnel0 created 00:25:04, never expire Type: static, Flags: NBMA address: 1.2.3.4
172.16.1.30/32 via 172.16.1.30, Tunnel0 created 00:08:13, expire
01:52:42 Type: dynamic, Flags: router implicit NBMA address: 80.187.114.1 (Claimed NBMA address: 172.20.225.217) (no-socket)
192.168.30.10/32, Tunnel0 created 00:00:06, expire 00:02:58 Type: incomplete, Flags: negative Cache hits: 1
RT_UMTS#traceroute 192.168.30.10
Type escape sequence to abort. Tracing the route to 192.168.30.10
1 172.16.1.10 228 msec 260 msec 228 msec 2 172.16.1.30 460 msec 468 msec 460 msec 3 192.168.30.10 468 msec 1200 msec 448 msec
Spoke Router:
interface FastEthernet0/0 ip address 192.168.20.1
interface Tunnel0 ip address 172.16.1.20 255.255.255.0 ip mtu 1400 ip nhrp authentication DMVPN_NW ip nhrp map multicast dynamic ip nhrp map 172.16.1.10 1.2.3.4 ip nhrp network-id 1 ip nhrp nhs 172.16.1.10 ip nhrp cache non-authoritative ip nhrp shortcut ip nhrp redirect ip tcp adjust-mss 1360 delay 1000 cdp enable tunnel source Cellular0/1/0 tunnel destination 1.2.3.4 tunnel key 10000 tunnel protection ipsec profile DMVPN-PROF
Hub Router:
interface Tunnel0 ip address 172.16.1.10 255.255.255.0 no ip redirects ip mtu 1400 ip nhrp authentication DMVPN_NW ip nhrp map multicast dynamic ip nhrp network-id 1 ip nhrp holdtime 360 ip nhrp cache non-authoritative ip nhrp redirect ip tcp adjust-mss 1360 no ip split-horizon eigrp 1 delay 1000 cdp enable tunnel source Dialer1 tunnel mode gre multipoint tunnel key 10000 tunnel protection ipsec profile DMVPN-PROF
Does "show ip route" show 172.16.1.30 as the gateway for
192.168.30.0/24? I think no. So why should your traceroute go directly to 172.16.1.30? Add the line "no ip next-hop-self eigrp 1" to the tunnel configuration of your hub router. Reset the eigrp adjacency and look again into your routing table.
On the spokes, you only need "ip nhrp shortcut", but for dynamic spoke-to-spoke connectivity, you need to configure a multipoint GRE (mGRE) tunnel interface on the spokes (similar configuration to the hub); this is a pt-pt spoke as there is a "tunnel destination" command present.
As you're using DMVPN Phase 3 (i.e. in 12.4(6)T or later) with NHRP shortcuts, then it's possible to have just a summary route advertised from the hub(s), and the improved NHRP process will correctly determine the next-hop. Note that traffic will still be forwarded via the hub until the spoke-spoke tunnel is built.
I'd also consider configuring a hold timer on all tunnels, (ip nhrp holdtime 300 is recommended).
Cheers,
Matt
Thank you guys for your hints.
Helmut, I followed your suggestion ("Add the line "no ip next-hop-self eigrp 1" to the tunnel configuration of your hub router. Reset the eigrp adjacency and look again into your routing table."), but it did not change the situation; I still have only the hub router as an eigrp neighbor.
Matt, do you suggest to configure an additional tunnel interface for the spoke-to-spoke communication, or do you want me to change my existing Tunnel0 interface into a mGRE tunnel?
("for dynamic spoke-to-spoke connectivity, you need to configure a multipoint GRE (mGRE) tunnel interface on the spokes (similar configuration to the hub); this is a pt-pt spoke as there is a "tunnel destination" command present.")
As I can either have a tunnel destination or a multipoint GRE tunnel, how would find the spokes their hub then (if I change my T0 interface)?
Mathias
You only need a single mGRE tunnel interface; NHRP will discover the Hub.
Here's a fragment from a working lab configuration (which was dual hubs within a single DMVPN network, but a similar configuration with the addition of "ip nhrp shortcut" should permit the dynamic spoke-spoke tunnels).
interface Tunnel0 bandwidth 10000 ip address 10.0.1.1 255.255.255.0 no ip redirects ip mtu 1400 ip nhrp authentication cisco ip nhrp map multicast 192.0.2.254 ip nhrp map 10.0.1.254 192.0.2.254 ip nhrp map multicast 192.0.2.253 ip nhrp map 10.0.1.253 192.0.2.253 ip nhrp network-id 1 ip nhrp holdtime 300 ip nhrp nhs 10.0.1.254 ip nhrp nhs 10.0.1.253 ip nhrp shortcut ip nhrp registration no-unique ip nhrp cache non-authoritative ip tcp adjust-mss 1360 delay 1000 tunnel source FastEthernet0/0 tunnel mode gre multipoint ! interface FastEthernet0/0 description DMVPN Spoke-1 NBMA Address ip address 192.0.2.1 255.255.255.0 duplex half speed auto
interface FastEthernet1/0 ip address 10.200.0.1 255.255.255.0 duplex auto speed auto no keepalive ! router eigrp 1 network 10.0.0.0 no auto-summary eigrp stub connected
Cheers,
Matt
Hi Mathias,
sorry I have not seen that your spoke tunnel is configured as point to point. Please follow the instruction from Matt and it should work.
Regards Helmut
Thank=B4s again, Helmut and Matt!
Matt, my problem is, that at the spokes, which are connected to the UMTS network, I do not have static IP addresses - each time they are switched off and on again, they have another address. I only have a static address for my hub router which is connected to the ADSL network (which is the 1.2.3.4 in my configuration).
It is not possible here in Germany to get a static IP address for UMTS.
Sorry, I missed to give you that information.
So I cannot just add another "ip nhrp map" with the address of my other spoke as your example suggests.
Do you see any chance to get this running with changing IP addresses at the spokes?
Thank=B4s again Mathias
No, you don't need static IPs on the spokes. Just configure your 'ip nhrp map' with the address of the hub; NHRP sorts out everything else. Your hub will advertise routes to the other spokes (or just a summary/default route) via the mGRE tunnel interface. NHRP will determine next-hop addresses, so you don't need a "tunnel destination" on the spoke; just an mGRE interface.
For spoke-to-spoke connectivity, the initial packets will go via the hub which will issue NHRP redirects telling the spokes of the direct address they can use to reach the spokes. There needs to be an mGRE interface on the spokes to terminate (potentially multiple) dynamic spoke-to-spoke tunnels.
Just remove your 'tunnel destination' and turn it into a mGRE tunnel interface and everything should just work.
Cheers,
Matt
