netflow top-talkers statistics
Oct 06, 2009 4 Replies
Jump to replies (4)
netflow top-talkers statistics open original image
Is there a freeware utility that keeps statistics of netflow top- talkers routed via a specific interface? I've configured the router properly and I have access to the needed information, but I need to keep records.
Is anyone familiar with such utility?
Thank you.
Giorgos
Not sure that it's what you you looking
Thanks M
I'll give it a try.
Thank you!
Giorgos
jimmyd had written this in response to
: I just saw your post.
I would suggest that you look at Scrutinizer. It supports all versions of Netflow, ingress/egress traffic, IPv6 and has one of the strongest reporting engines out there.
It also is one of the only collectors to report on ASA Netflow!
and yes it is free . . . .
------------------------------------------------ Jimmy D Netflow Evangelist!
------------------------------------- snipped-for-privacy@gmail.com wrote:
Hi Giorgos
Have a look @ solarwinds.com. they have a freeware netflow-utility which records data for a single hour. You have to restart the app to see more...
stephan
