Ok so i have setup a static route
Code: ip nat inside source static 10.1.2.5 x.x.85.123 route-map SDM_RMAP_1 extendable.
(the route-map is defined to let the traffic go through the vpn instead of our the default nat).
Everything seems to be ok when the connection is initiated by the outside. (packets go from outside(x.x.85.123) to inside(10.1.2.5) and responses go to the internet appearing to come from x.x.85.123.
The problem i have is if a connection is initiated from the inside (10.1.2.5) and is going out. It ends up coming from x.x.85.123 (the outside ip address of the router). I know this because if i use a whatsmyip service from 10.1.2.5 it reports the ip address of x.x.
85.122.
What do i need to do so that all trafic initiated from 10.1.2.5 goes out translated as coming from x.x.85.123 instead of x.x.85.122
Her is my config with pertinent info marked with comments.
