NAT ACL Questions
Oct 25, 2007 0 Replies
I am having an 'interesting' time trying to figure out some log entries associated with NAT on IOS 12.4 on a 28xx router. Here are some relivant snippits of the config:
interface GigabitEthernet0/0 description Uplink to Internet ip address STATIC.NETBLOCK.IP.253 255.255.255.224 ip access-group internet-in in ip nat outside ... ! interface GigabitEthernet0/1 description Downlink from firewall ip address WAN.NETBLOCK.1.253 255.255.255.252 ip nat inside ... ! ip nat pool corp-natpool STATIC.NETBLOCK.IP.251 STATIC.NETBLOCK.IP.252 prefix-length 27 ip nat inside source list 10 pool corp-natpool overload ip nat inside source static tcp A.WAN.NETBLOCK.IP PORT_I STATIC.NETBLOCK.IP.250 PORT_O extendable ... more static NATs ... ! access-list 10 permit 10.0.0.0 0.255.255.255 access-list 10 deny any log !
I used 'log' on the deny to see if any internal systems were spoofing IPs. (Yes, I know that 'deny' does not deny access, and that it only indicates that the packet is not NAT-ed.) The resulting log messages were 'interesting' and really did not make a lot of sense:
list 10 denied 0 0.0.0.0 -> A.STATIC.NAT.IP, 6 packets list 10 denied 0 0.0.0.0 -> A.DYNAMIC.NAT.IP, 7 packets list 10 denied 0 0.0.0.0 -> A.ROUTED.INTERNET.IP, 8 packets
Not sure where my nul source IPs were coming from, I put ACLs on each interface to log them inbound, but I never saw any. Thus, I came to the conclusion the router must be generating them. Next, I started sniffing (tshark) outbound traffic, but again never saw any nul source IPs.
Figuring the standard ACLs were not giving me enough information, I made the following configuration changes:
ip access-list extended ip-nat-pool permit ip 10.0.0.0 0.255.255.255 any deny ip any any log-input ! ip nat inside source list ip-nat-pool pool corp-natpool overload no ip nat inside source list 10 pool corp-natpool overload
Now, I started getting some really interesting output!
list ip-nat-pool denied udp A.ROUTED.INTERNET.IP(0) (GigabitEthernet0/1 ) -> A.ROUTED.INTERNET.IP(0), 1 packet list ip-nat-pool denied udp A.STATIC.NETBLOCK.IP(0) (GigabitEthernet0/1 ) -> A.ROUTED.INTERNET.IP(0), 1 packet list ip-nat-pool denied udp STATIC.NETBLOCK.IP.253(0) ->
A.ROUTED.INTERNET.IP(0), 1 packet list ip-nat-pool denied tcp A.STATIC.NETBLOCK.IP(0) ->
A.ROUTED.INTERNET.IP(0), 6 packets list ip-nat-pool denied icmp A.STATIC.NETBLOCK.IP ->
A.ROUTED.INTERNET.IP (0/0), 2 packets
A few observations: 1) Only UDP packets ever generate an interface name associated with the log message, and then, only IP addresses that are NOT the IP assigned to the Internet facing interface. More interestingly, many of the UDP packets claim to have a global IP address originating from an interface that has on WAN IPs. (I have sniffed the network to ensure that no global IPs are actually inbound to the GigabitEthernet0/1 interface.)
2) All UDP and TCP source and destination ports are "0" and all ICMP is type "0/0". In addition, the ICMP Echo Reply (0/0) is NOT sent in response to an ICMP Echo Request.
3) The original standard ACLs appear to be logging completely different information for the same event. That is, protocol=0 and source_IP=0.0.0.0 for standard ACLs vs. UPD or TCP traffice with varying source IPs, but with source and destination port=0, or ICMP 0/0 entries with similar characteristics.
Question! Can anyone explain these observed behaviors?
Now, this is what I **REALLY** do not understand. Consider the following:
host-behind-firewall$ ping -c3 scanme.insecure.org ... ping works, output deleted...
Router log entry with same time stamp as start of ping: list ip-nat-pool denied udp 205.217.153.62(0) (GigabitEthernet0/1 ) ->
FWD.NAME.SERVER.IP(0), 1 packet
host-behind-firewall$ host scanme.insecure.org scanme.insecure.org has address 205.217.153.62
Question! Why does some activity associated with the ping (clearly, not the name server lookup) cause router to generate a UDP packet that appears to originate from interface to the firewall, and have a source IP of the address to be pinged and a destination address (global IP) of the name server doing the lookup?
I would really like to understand what is going on here. Any help GREATLY appreciated!
