multipe tunnels question
May 19, 2005 1 Replies
I'm running IPSEC tunnels to three sites from my cisco. One of the sites says they now need a GRE tunnel. I have one serial interface for my WAN and an ethernet interface for my internal network. There is a
2nd Ethernet interface for my DMZ.
I know nothing about GRE tunnels at this point, from configs I have looked at, it appears you setup another virtual interface or something. If I do this, will it be compatible with my current IPSEC tunnels which are configured for the Serial interface? Can I have both types of tunnels and are there any restrictions?
Thanks for your help
GRE works with tunnel-interfaces (TunnelX). Just configure tunnel source, tunnel destination and an unnumbered interface. Make sure to allow the GRE-protocol pass your access-lists. I've configured some GRE-tunnels and they all work well. Nevertheless, GRE without encryption isn't a very good solution. Just modify the corresponding access-list to trigger on GRE-packets.
access-list 100 permit gre host x.x.x.x host y.y.y.y
And don't forget to apply the crypto map on the physical *and* the tunnel-interface. IPsec and GRE are working together perfectly, even if on the same interface. I only once had to "optimize" the max-mss.
\cd
