Management interface Catalyst.
Aug 11, 2006 1 Replies
Hi all,
our system experienced a black-out and the UPS too. Our big switch (Catalyst 4006) went down. I saw the management interface was put on shutdown mode. I saved the config while using that interface, so I can not figure out why the switch decided to shut it down after the black-out Any hint or explanation? I'd like to hear your say in order to know if the switch behaves so weirdly not only with sc0 but with any other component. How I could eventually test if everything is working fine?
TIA
Alex.
It maybe a bug, so it may assist responders if you post the output of show version and show module.
