IPSEC VPN between 506e and 501
Aug 15, 2008 2 Replies
Hi all,
Im having trouble with a site to site ipsec vpn connection.
Yesterday I had to change over to a new internet connection, so I swapped out the router and changed to a new set of ip address at one side of the connection but now I cannot reestablish connection.
it appears IKE is coming up, I think it is the router but ive disabled its firewall so not sure what else it could be. its a nortel BSR 252 if that helps
heres some of the syslog -
08-15-2008 10:59:26 Local4.Debug 192.168.1.1 Aug 15 2008 11:00:01: %PIX-7-702204: ISAKMP Phase 1 retransmission (local pix's outside ip (initiator), remote remote pix's ip)
08-15-2008 10:59:10 Local4.Debug 192.168.1.1 Aug 15 2008 10:59:44: %PIX-7-702208: ISAKMP Phase 1 exchange started (local pix's outside ip (initiator), remote remote pix's ip)
08-15-2008 10:59:10 Local4.Debug 192.168.1.1 Aug 15 2008 10:59:44: %PIX-7-702303: sa_request, (key eng. msg.) src= pix's outside ip, dest= remote pix's ip, src_proxy= 192.168.1.0/255.255.255.0/0/0 (type=4), dest_proxy= Welling/255.255.255.0/0/0 (type=4), protocol= ESP, transform= esp-3des esp-md5-hmac , lifedur= 28800s and 4608000kb, spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x4004
if you need anymore info please ask ?
Thanks
Alex
.1.1 =A0 =A0 Aug 15 2008 11:00:01:
.1.1 =A0 =A0 Aug 15 2008 10:59:44:
I have come cross same issue before and I rest the key from both side and it works, try it ..
Also, make sure that the interesting traffic , access-list , are symmetric to each other.
Regards,
