How to make an ack on pix firewall with PDM ???
Dec 21, 2005 1 Replies
Walter Roberson
I did see your previous posting on this topic a couple of days ago, but I did not answer. In order to answer the question you asked, someone would have to give you a long list of "click on this, scroll down to that, click there, enter this, tab right, tick that"... Speaking for…
hi i try to work with PDM and I am a newbie with pix, so need help I want to make an ack which will release traffic on services http,https,ftp,ftp data,pop3+smtp,domain,www and will block all other that don't match I make some service group and assign this rule to interface inside and make with action "permit" to outside any. but it don't work .....all traffic is block what's gone wrong ? some can help or tell where I can find description to work with PDM ??? and I want block some ip's on interface outside from access to my network , how to make this i am using PAT translation.
regards
Speaking for myself: I find that giving those kinds of answers is too much effort for me to bother.
It would not take us very long to give you the Command Line Interface (CLI) commands that would give you the configuration you wanted, so if you can access the CLI (or find the PDM screen that allows you to send things to the CLI) then we could get you running. Afterwards, you could go into PDM and see what had appeared where, and that would give you clues on how to make changes through PDM in the future.
