Help with router configuration
Oct 22, 2005 3 Replies
Jump to replies (3)
Hi there I have a Cisco router which has 2 configured interfaces
E0:201.139.xx.24 E1:200.201.xx.161
E0 has three hosts
201.139.xx.25(used)
201.139.xx.26(free)
201.139.xx.27(used)
E1 has three host
200.201.xx.162(used)
200.201.xx.163(used)
200.201.xx.164(used)
I ran out of IP address for hosts in E1 subnet, is it possible to assign E0's free IP address (201.139.xx.26)to host in E0.if yes how can I achieve this.
Any help would be greatly appreciated.
Niju
These IP addresses are public IP addresses, so either ask your ISP for a larger allocation or use network address translation (NAT).
The address ranges you show should have several more usable addresses. The smallest subnet that contains E0's address is 201.139.xx.16/20, with usable addresses 201.139.xx.17-30. And the smallest subnet for E1 is
200.201.xx.160/29, with usable addresses 200.201.xx.161-166. So why are you out of addresses?
My apologies for not making this clear at front. The addresses i have mentioned here are only example and i have completely used all the address in E1 only free address i have is on E0 subnet.
Niju
