Help, FTP thru ASA not working
Jul 04, 2007 1 Replies
I can't figure out why outbound ftp is not working. Could anyone help?
same-security-traffic permit inter-interface same-security-traffic permit intra-interface object-group service ExchangeOWA tcp description Exchange Web and Mobile Access port-object eq smtp access-list inside_nat0_outbound extended permit ip any 192.168.100.0
255.255.255.192 access-list inside_nat0_outbound extended permit ip 192.168.0.0
255.255.0.0 192.168.123.0 255.255.255.0 access-list inside_nat0_outbound extended permit ip 192.168.1.0
255.255.255.0 192.168.222.0 255.255.255.0 access-list inside_nat0_outbound extended permit ip 192.168.1.0
255.255.255.0 192.168.111.0 255.255.255.0 access-list dzm extended permit ip any any access-list dzm extended permit icmp any any access-list ouside extended permit ip any any access-list cont_in extended permit ip host 66.66.66.135 any access-list outside extended permit tcp any host 66.66.66.133 object- group ExchangeOWA access-list outside extended permit tcp any host 66.66.66.137 eq pptp access-list outside extended permit gre any host 66.66.66.137 access-list outside extended permit icmp any any echo-reply access-list outside_cryptomap_20 extended permit ip 192.168.0.0
255.255.0.0 192.168.123.0 255.255.255.0 access-list Split_tunnel_ACL standard permit 192.168.0.0 255.255.0.0 access-list outside_cryptomap_80 extended permit ip 192.168.1.0
255.255.255.0 192.168.111.0 255.255.255.0 access-list outside_cryptomap_60 extended permit ip 192.168.1.0
255.255.255.0 192.168.222.0 255.255.255.0 access-list inside extended permit tcp any host 66.201.66.66 eq pptp access-list inside extended deny tcp any any eq pptp access-list inside extended permit ip any any pager lines 24 logging enable logging asdm informational mtu outside 1500 mtu inside 1500 mtu management 1500 ip local pool CCCC-pool 192.168.100.1-192.168.100.50 mask
255.255.255.0 icmp permit any outside icmp permit any inside nat-control global (outside) 10 interface global (inside) 200 192.168.0.0 netmask 255.255.0.0 nat (inside) 0 access-list inside_nat0_outbound nat (inside) 10 0.0.0.0 0.0.0.0 static (inside,outside) tcp 66.66.66.133 smtp 192.168.1.16 smtp netmask 255.255.255.255 static (inside,outside) tcp 66.66.66.133 www 192.168.1.16 www netmask
255.255.255.255 static (inside,outside) tcp 66.66.66.133 https 192.168.1.16 https netmask 255.255.255.255 static (inside,outside) 66.66.66.134 172.30.1.50 netmask
255.255.255.255 static (inside,outside) 66.66.66.137 192.168.1.10 netmask
255.255.255.255 access-group outside in interface outside access-group inside in interface inside route outside 0.0.0.0 0.0.0.0 66.66.66.129 1 route inside 192.168.1.0 255.255.255.0 192.168.10.2 1 route inside 172.30.1.0 255.255.255.0 192.168.10.2 1 route inside 172.20.20.0 255.255.255.0 192.168.10.2 1 route inside 192.168.101.0 255.255.255.0 192.168.10.2 1 route inside 192.168.102.0 255.255.255.0 192.168.10.2 1 route inside 192.168.103.0 255.255.255.0 192.168.10.2 1 route inside 192.168.106.0 255.255.255.0 192.168.10.2 1 route inside 192.168.6.0 255.255.255.0 192.168.10.2 1 route inside 192.168.3.0 255.255.255.0 192.168.10.2 1 route inside 192.168.2.0 255.255.255.0 192.168.10.2 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute port-forward sf 1222 192.168.1.1 243
telnet 0.0.0.0 0.0.0.0 inside telnet timeout 30 ssh 0.0.0.0 0.0.0.0 outside ssh timeout 10 console timeout 0 management-access inside dhcpd lease 3600 dhcpd ping_timeout 50 ! class-map global-class match any ! policy-map global-policy class global-class csc fail-open inspect pptp class class-default csc fail-close
You don;t have a specific rule for ftp so I assume that you are using one of the 'permit ip any' rules. Are you using PASV ftp? If not try it as the return port (tcp 20) is presumably being blocked.
snipped-for-privacy@gmail.com wrote:
