difference between the 1121 and 1131 wireless access points
Jun 17, 2007 1 Replies
Most relevant reply
Aaron Leonard
1131: 262MHz CPU 11g and 11a radios 32MB RAM/16MB flash console port supports HREAP mode 1121: 197MHz CPU 11g radio only 16MB RAM/8MB flash no console port no HREAP support Due to the 1121's memory contstraints, you should not expect it to get fewer new features and have a…
difference between the 1121 and 1131 wireless access points open original image
i have requested quotes from several vendors for the lap-1131g AP. some provided this . others provided for the 1121. i find no mention of the 1121 on cisco' s site, but i do sort of recall that it existed. is it a good guess that the only diff's is memory and proc speed? or are there other diff's too.? can someonepoint me to the specs for the 1121. (the 1131 specs are readily available on cisco's site.) tnx ams
Due to the 1121's memory contstraints, you should not expect it to get fewer new features and have a shorter software support lifetime.
Looks like the PMs have tried to hide the 1121's product info, but you can still find it at
Hth,
Aaron
