Cisco VPN Client: Idle timeout every few minutes--pls help
Jul 14, 2006 2 Replies
Cisco VPN Client: Idle timeout every few minutes--pls help open original image
Hi all: I can make the VPN connection to work fine, but if I don't have network activity for something like 4 or 5 minutes, the VPN connection dies with error: Secure VPN Connection termindated by Peer. Reason 431: Configured Maximum Idle Time for Session Exceeded.
I am using a Cisco VPN Client 4.0.5(c) / WinXP Pro to connect to work from home. I have a wireless DSL router (Westel) from Verizon.
I am at my wit's end. The VPN folks claim all is well at their end, they do not have idle timout setting of few minutes, and that something is wrong at my end. They may be right, but I am disappointed that they can't help me troubleshoot at my end, if in fact the issue is at my end.
So far:
-Tried wired connection, instead of wireless
-Made sure I am using IPSEC over UDP instead of TCP (on VPN folk's recommandation)
-Added ForcedKeepAlives=1 to my profile
-Enabled IPSEC ESP (client) and IPSEC IKE (port forwarding) services in my home router (honestly don't know what they mean, just monkeying around)
-I even tried to run a bat script that simply pings a server, sleeps for 3 mins and goes at it again.
-I tried keeping a putty telnet session to a server open.
No matter what, unless I am actively using the browser or some appliation that generates network traffic, VPN connection is gone in a few minutes?
What on the earth is happening??
TIA.
Here's a chunk of log from my VPN client that I believe captures a timeout which may mean something to any of you gurus:
654 09:27:15.375 07/14/06 Sev=Info/6 IKE/0x63000054 Sent a keepalive on the IPSec SA
655 09:27:25.375 07/14/06 Sev=Info/6 IKE/0x63000054 Sent a keepalive on the IPSec SA
656 09:27:35.375 07/14/06 Sev=Info/6 IKE/0x63000054 Sent a keepalive on the IPSec SA
657 09:27:45.312 07/14/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 198.74.13.200
658 09:27:45.312 07/14/06 Sev=Info/4 IKE/0x63000014 RECEIVING
You may wish to investigate the Cisco VPN Client GUI Error Lookup Tool:
Message Type - Select "Reason"
Message Number/Value - Select "431"
------------------------------------------- Description or Action: The VPN connection was idle for longer than the time allowed by the administrator.
Try going to User Management, Groups, select the group that the user belongs to.
Then, select Authentication Servers.
Hightlight the server.
Then, select Modify.
Then, change the Timeout value from 1 to 4
Hope this helps.
Brad Reese BradReese.Com - Global Cisco Systems Pre-Sales Support
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
Thank you Brad. VPN folks have earlier insisted that server side setting is not the issue, so this is useful info.
I had seen the error explanation, but not on Cisco's site, so I now have something authoritative I can show to VPN folks. The fix you mentioned I hadn't seen earlier, so that's definitely helpful.
I am curious...what is the meaning of these settings from 1 to 4? Is 4 mins the max idle time that is allowed? If that's true, it explains why I timeout after around 4 mins or so. The application I mainly use over VPN is not very chatty, so unless I am using it actively, (say I swithced to MS Word for a few minutes), it would make sense that I time out after 4 mins. However, I can't believe that 4 mins is all you get, so I hope my understanding is wrong.
Regards.
wrote:
