Cisco 877 Router - VLAN/DMZ Configuration/Problem
Feb 15, 2007 1 Replies
Dear Group,
I am trying to set up a Cisco 877 with an additional VLAN. This is to provide wireless clients access out on the internet using the same link as the corporate network but segregated from the local LAN. On a Cisco 877 I believe that the DMZ has to be configured via use of VLANs rather than on other models.
I have created an additional VLAN on the router with an ID of 2 using the vlan database and this is defined as follows:
cisco877ftc(vlan)#show VLAN ISL Id: 1 Name: default Media Type: Ethernet VLAN 802.10 Id: 100001 State: Operational MTU: 1500 Translational Bridged VLAN: 1002 Translational Bridged VLAN: 1003
VLAN ISL Id: 2 Name: VLAN0002 Media Type: Ethernet VLAN 802.10 Id: 100002 State: Operational MTU: 1500
VLAN ISL Id: 1002 Name: fddi-default Media Type: FDDI VLAN 802.10 Id: 101002 State: Operational MTU: 1500 Bridge Type: SRB Translational Bridged VLAN: 1 Translational Bridged VLAN: 1003
VLAN ISL Id: 1003 Name: token-ring-default Media Type: Token Ring VLAN 802.10 Id: 101003 State: Operational MTU: 1500 Bridge Type: SRB Ring Number: 0 Bridge Number: 1 Parent VLAN: 1005 Maximum ARE Hop Count: 7 Maximum STE Hop Count: 7 Backup CRF Mode: Disabled Translational Bridged VLAN: 1 Translational Bridged VLAN: 1002
VLAN ISL Id: 1004 Name: fddinet-default Media Type: FDDI Net VLAN 802.10 Id: 101004 State: Operational MTU: 1500 Bridge Type: SRB Bridge Number: 1 STP Type: IBM
VLAN ISL Id: 1005 Name: trnet-default Media Type: Token Ring Net VLAN 802.10 Id: 101005 State: Operational MTU: 1500 Bridge Type: SRB Bridge Number: 1 STP Type: IBM
I have then defined the FastEthernet3 interface on the router with "switchport access vlan 2" and configured interface "vlan2" with IP details etc.
Plugged into Fe3 on the router is a 10/100 switch which has devices connected to it with IP addresses assigned in the 192.168.0.0/24 range. I am not trunking out to a vlan switch.
My problem is that I can not ping any devices in the 192.168.0.0/24 network from the 877 and they cannot ping the 192.168.0.254 address of the router.
I have attached my config at the bottom of this post. If anyone has any advice I would greatfully appreciate any help as this is getting rather frustrating.
Regards, Ross
! NVRAM config last updated at 09:04:46 UTC Thu Feb 15 2007 by admin ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname cisco877ftc ! boot-start-marker boot-end-marker ! enable secret 5 $1$UIDN$pHyk1FAPMPCeRQVConb.h/ ! aaa new-model ! ! aaa authentication login default local aaa authorization network RemoteVPN local ! aaa session-id common ! resource policy ! ip cef ! ! ! ! ip domain name [removed].gov.uk ip inspect name ios-fw cuseeme timeout 3600 ip inspect name ios-fw ftp timeout 3600 ip inspect name ios-fw realaudio timeout 3600 ip inspect name ios-fw smtp timeout 3600 ip inspect name ios-fw udp timeout 15 ip inspect name ios-fw tcp timeout 3600 ip inspect name ios-fw h323 timeout 3600 ! ! ! username admin password 0 [removed] ! ! ! crypto isakmp policy 10 encr 3des hash md5 authentication pre-share group 2 ! crypto isakmp client configuration group RemoteVPN key [removed] dns 172.31.1.62 wins 172.31.1.62 domain [removed].gov.uk pool rvpnpool ! ! crypto ipsec transform-set TRANSFORM1 esp-3des esp-md5-hmac ! crypto dynamic-map dynmap 10 set transform-set TRANSFORM1 ! ! crypto map MYSET isakmp authorization list RemoteVPN crypto map MYSET client configuration address respond crypto map MYSET 101 ipsec-isakmp dynamic dynmap ! ! ! ! interface ATM0 no ip address no atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 description VLAN2-WLAN-DMZ switchport access vlan 2 ! interface Vlan1 ip address 172.31.1.1 255.255.255.0 ip access-group 122 in ip nat inside ip inspect ios-fw in ip virtual-reassembly ! interface Vlan2 ip address 192.168.0.254 255.255.255.0 ip access-group 133 in ip nat inside ip inspect ios-fw in ip virtual-reassembly ! interface Dialer1 ip address negotiated ip access-group 111 in ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap callin ppp chap hostname [removed]@hg40.btclick.com ppp chap password 0 [removed] crypto map MYSET ! ip local pool rvpnpool 172.16.1.1 172.16.1.254 ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! no ip http server no ip http secure-server ip nat inside source list 102 interface Dialer1 overload ip nat inside source static tcp 172.31.1.62 25 1.1.1.1 25 extendable ! access-list 102 deny ip 172.31.1.0 0.0.0.255 172.16.1.0 0.0.0.255 access-list 102 permit ip 172.31.1.0 0.0.0.255 any access-list 102 permit ip 192.168.0.0 0.0.0.255 any access-list 111 permit ip 172.16.1.0 0.0.0.255 172.31.1.0 0.0.0.255 access-list 111 permit tcp any host 1.1.1.1 eq smtp access-list 111 permit tcp any host 1.1.1.1 eq 22 access-list 111 permit icmp any any echo access-list 111 permit icmp any any echo-reply access-list 111 permit udp any any eq isakmp access-list 111 permit udp any any eq non500-isakmp access-list 111 permit esp any any access-list 111 deny ip any any access-list 122 permit ip 172.31.1.0 0.0.0.255 any access-list 133 permit ip 192.168.0.0 0.0.0.255 any dialer-list 1 protocol ip permit ! ! ! ! control-plane ! ! line con 0 no modem enable line aux 0 line vty 0 4 transport input ssh ! scheduler max-task-time 5000 ntp server 81.5.136.18 ! webvpn context Default_context ssl authenticate verify all ! no inservice ! end
cisco877ftc#
I think you have already run your test after removing all ACL on VLAN 2. The way you are reporting the problem reminds me a problem very similar to what I got few weeks ago. Having the router with no configuration and giving VLAN 1 just an IP address, nothing worked. I disabled the STP and everything ran smoothly. At least try not to use the switch when you want to ping the VLAN 2 interface.
HTH Alex
Keep us informed
