Basic Routing issue
Aug 01, 2006 2 Replies
My configuration follows. I've got a Cisco 1700 router that is servicing between 2 networks - one is public - Ethernet0 and one is internal/private - fastethernet. I am trying to allow mail to go through the firewall. I am having problems getting any traffic to flow
- inside or out. I was hoping that someone could look at this and give me some guidence.
Thanks!!
Using 1605 out of 29688 bytes ! version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname owh-inc ! boot bootstrap flash:c1700-o3sy756i-mz.121-5.YB1.bin boot system rom logging rate-limit console 10 except errors enable secret 5 $1$VkT3$IkEHnWrgFGgkJt2I4vj8Y1 enable password ***** ! memory-size iomem 25 ip subnet-zero ! ! no ip finger ip name-server 65.106.1.196 ip name-server 65.106.7.196 ip audit notify log ip audit po max-events 100 no ip dhcp-client network-discovery ! ! ! ! ! interface Ethernet0 description outside ip address 64.221.206.163 255.255.255.0 ip access-group 100 in ip nat outside no ip mroute-cache full-duplex ! interface FastEthernet0 description inside ip address 192.168.100.1 255.255.255.0 ip nat inside no ip mroute-cache speed auto ! interface Serial0 no ip address no ip mroute-cache shutdown ! router rip network 64.0.0.0 network 192.168.100.0 ! ip nat inside source static tcp 192.168.100.1 23 interface Ethernet0 23 ip nat inside source static tcp 192.168.100.113 25 64.221.206.163 25 extendable ip classless ip route 0.0.0.0 0.0.0.0 64.221.206.161 no ip http server ! access-list 1 permit 192.168.100.0 0.0.0.255 access-list 100 permit tcp any 192.168.100.0 0.0.0.255 established access-list 100 permit tcp any 192.168.100.0 0.0.0.255 eq telnet access-list 100 permit tcp any 192.168.100.0 0.0.0.255 eq smtp dialer-list 1 protocol ip permit dialer-list 1 protocol ipx permit ! ! line con 0 transport input none line aux 0 line vty 0 4 password wbai001 login ! end
Access-list 100 ... why is it allowing access from the internet to private IP addresses? Traffic coming into that interface will be destined for the global IP, not the private one.
Also, because of that acl any client on the inside sending out a DNS query will not get a reply as your acl will block the reply from the server.
Chris.
As Chris says:- (I had already written following)
! ! RELPACE THIS ! ip nat inside source static tcp 192.168.100.1 23 interface Ethernet0 23
! WITH THIS
logging buffered 50000 logging buffered debug service timestamps debug datetime msec localtime service timestamps log datetime localtime no logg con ! console logging can adversely affect CPU ! but is OK for testing.
ip nat inside source route-map nonat interface Ethernet0 overload ip nat inside source static tcp 192.168.100.1 23 interface Ethernet0 23
route-map nonat permit 10 match ip address 110
access-list 100 permit tcp any host 64.221.206.163 established access-list 100 permit tcp any host 64.221.206.163 eq telnet access-list 100 permit tcp any host 64.221.206.163 eq smtp !! Adding next 3 lines gives you better diagnostics - for troubleshooting !! if there is too much in the logs for you, you can !! always take it out later access-list 100 deny tcp any any log access-list 100 deny tcp any any log access-list 100 deny ip any any log
!! You may need the next 2 lines I am not sure access-list 110 deny ip host 192.168.100.1 eq 23 any eq 23 access-list 110 deny ip host 192.168.100.113 eq 25 any eq 25 !! access-list 110 permit ip 192.168.100.0 0.0.0.255 any
Look on cisco site for "nat order of operations"
Fix up DNS yourself:-)
