Am I right to think that a customer firewall is stopping my trace?
May 06, 2005 1 Replies
Walter Roberson
:My equipment is a cisco 2610 IOS c2600-i-mz.122-10b. :I can ping the gateway 172.16.32.2 and the router is applying the :static route: :However a trace to the remote host 172.16.104.12 always fails: :No acl seems be blocking my trace on my router: You might have to…
I configured the following static route: ip route 172.16.104.0 255.255.254.0 172.16.32.2
Ethernet 0/0 address is 172.16.32.1/20
I can ping the gateway 172.16.32.2 and the router is applying the static route: xxx#sh ip route 172.16.104.0 Routing entry for 172.16.104.0/23 Known via "static", distance 1, metric 0 Redistributing via ospf 99 Advertised by ospf 99 subnets route-map static_ospf_ge Routing Descriptor Blocks:
  • 172.16.32.2 Route metric is 0, traffic share count is 1
However a trace to the remote host 172.16.104.12 always fails: Tracing the route to 172.16.104.12
1 * * *
2 *
No acl seems be blocking my trace on my router: xxx#sh ip access-lists Standard IP access list 25 permit 192.168.0.0, wildcard bits 0.0.255.255 permit 204.231.97.0, wildcard bits 0.0.0.255 Standard IP access list static_to_ospf_ge permit 172.16.48.0, wildcard bits 0.0.1.255 (1 match) check=74 permit 172.16.50.0, wildcard bits 0.0.1.255 (1 match) check=73 permit 172.16.104.0, wildcard bits 0.0.1.255 (3 matches) check=70 permit 172.16.88.0, wildcard bits 0.0.3.255 (10 matches) check=60 Extended IP access list 101 deny ospf any any permit ip any any (48 matches)
I asked to the customer to check if this gateway 172.16.32.2 which should be a router has implemented some acl that are stopping my trace or if there could be a firewall somewhere.Am I right in your opinion?
In article , maxxot2005 wrote: :My equipment is a cisco 2610 IOS c2600-i-mz.122-10b.
You might have to specifically enable processing of icmp time-exceeded messages on your router. No blocking ACL is necessary if your router is throwing away what it gets.
You should be able to check this by using a packet debug, or putting an ACL with a 'log' statement on the return traffic.
