access list problem
Aug 25, 2006 22 Replies
what command? Here is sh line before and after the second host telenets in
before edu-cer-3750A#show line Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int 0 CTY - - - - - 0 0
0 -
  • 1 VTY - - - - 1 20 0
0 - 2 VTY - - - - 1 7 0 0 - 3 VTY - - - - 1 0 0 0 - 4 VTY - - - - 1 0 0 0 - 5 VTY - - - - 1 0 0 0 - 6 VTY - - - - 1 0 0 0 - 7 VTY - - - - 1 0 0 0 - 8 VTY - - - - 1 0 0 0 - 9 VTY - - - - 1 0 0 0 - 10 VTY - - - - 1 0 0 0 - 11 VTY - - - - 1 0 0 0 - 12 VTY - - - - 1 0 0 0 - 13 VTY - - - - 1 0 0 0 - 14 VTY - - - - 1 0 0 0 - 15 VTY - - - - 1 0 0 0 - 16 VTY - - - - 1 0 0 0 -
After second host telnet in edu-cer-3750A#show line Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int 0 CTY - - - - - 0 0
0 -
0 -
  • 2 VTY - - - - 1 8 0
edu-cer-3750A#
The "show access-list 1" command. Are you getting hits on the ACL?
Doan
UPGRADE THE IOS SOFTWARE !!!
I suspect you have stepped on this bug:
CSCed10210
Headline access-class on vty fails to secure vty after reboot Product IOS Feature OTHERS Components Duplicate of Severity 2 Severity help Status Verified Status help First Found-in Version 12.1(14)EA1 All affected versions First Fixed-in Version 12.2(18)SE, 12.1(19)EA1a, 12.1(20)EA1, 12.2(20)SE,
12.1(14)AX1 Version help Release Notes
Symptom: A Catalyst 3750 or 2970 switch running 12.1(19)EA1 or earlier may allow telnet sessions to the device from unauthorized hosts with an access-class applied inbound to the vty lines.
Thie issue occurs only after a reboot and only if a keystroke has not been echoed to the console port. After the console port has received a single character from some kind of terminal, the access-class applied to the vty will activate and filter any new inbound connections.
The configuration under the vty will look similar to this: line vty 0 4 password cisco access-class 3 in login ! access-list 3 permit host 10.1.1.1 access-list 3 deny any
When this configuration is applied, any host will be able to telnet to the switch until at least a character is sent to the console port.
Conditions: This only affects Catalyst 3750 and 2970 switches running 12.1(19)EA1 or earlier. This does not affect any other product.
Workaround:
  1. Enter at least one character on the console port after reload.
  2. Upgrade to Cisco IOS 12.1(19)EA1a or higher. Cisco IOS Release
12.1(19)EA1a is expected to be available for download from cisco.com after December 15, 2003.
