3750 Port based ACL logging
May 15, 2008 2 Replies
Hi all, With the below test config I can't seem to generate a single log entry from the ACL. Has anyone had experience in logging with port based ACL's on the 3750? With the below config the icmp traffic is being dropped - just not logged.
3750 running Adv IP Services... interface GigabitEthernet1/0/25 switchport access vlan 701 switchport mode access ip access-group TEST in
ip access-list extended TEST deny icmp any any log permit ip any any log
ip access-list log-update threshold 1
"show access-lists hardware counters" does show drops and I cant ping through this interface with the ACL applied. It just wont log any ACE entry matches.
Cheers Kent.
Have you configured logging?
logg buffered !
