2 way redistribution
May 08, 2005 1 Replies
Hi guys, I am trying to achieve 2 way redistribution between ISIS and EIGRP. My conf is shown below. Now my question is whats the use of redistibued connected command there (inbetween asteriks)
RTR2> en
RTR2# config t
RTR2(config-router)# router isis
RTR2(config-router)# redistribute eigrp 100 level-1 metric 50
RTR2(config-router)# exit
RTR2(config)# router eigrp 100
RTR2(config-router)# redistribute isis level-1 metric 64 10 255 1 1500
RTR2(config-router)# redistribute connected
RTR2(config-router)# ^z
RTR2# copy running-config start up-config.
To asvertise a link into ISIS, you need an 'ip router isis' under that interface (which also tells ISIS to send IIHs out that interface)...
Let's say you want to advertise a link, but don't want to run ISIS on an interface, 'redistribute connected' is your friend.
Jonathan
