Allen Tel hinged wall mount bracket screws
Sep 30, 2004 2 Replies
I ran into a wall mount rack/bracket made by Allen Tel. The model is AT55HM-10, and I was asked to replace the small wire management with something a bit bigger, easy enough. The problem I have encountered was that the original wire manager was held in by wire-ties, and when I attempted to use normal rack screws, I encountered that they are too big for Allen Tel!
Years ago I remember hoarding the smaller rack screws when I ran into them, but eight years of almost exclusive carrier contract work has completely depleted my stash to coworkers/ex-coworkers and I probably haven't needed one in about five years. I figure before the weekend is over I might head to Lowe's/Home Depot and see what I can find. Anyone know of the specs for the screws on these Allen Tel hinged wall mount brackets?
TIA
Rack screws typically come in 12-24 thread, but I seem to remember some that used 10-32. It's possible your rack has 10-32 tapped holes and the screws you've got are 12-24.
All the Chatsworth open racks use the 12-24 rack screws, which are hard to find even in hardware stores. But they come with a bag of them, which is usually enough with a few left over. They don't have threads on the end for a fraction of an inch, so they're easier to get started with heavy equipment.
The old standard RETMA rack screws are 10-32 by maybe a half inch or
3/4" long. But newer racks come with those cheap clip-on nuts that have a thread something like a sheet metal screw. And then there are the racks from foreign countries that use metric screws. I'm not sure what size they are.
