I couldn't get Netstumbler to work with some of my cards and dongles so I did some searching on the net and learned that a wireless card's signal strength is available as a WMI (Windows Management Instrumentation) value. So I put together this quick and dirty script that gives a continuous real time display of received signal strength for an active wireless connection. It's worked with all my clients, even ones that don't work under Netstumbler. I'm posting it here thinking that maybe someone else will find it useful. Perhaps someone will suggest improvements too.
To use the script, just paste the text below into an editor like Notepad and save it with the name bjs555monitor.vbs. Then open a command window and navigate to the folder where you saved the script. Start the script by typing cscript bjs555monitor.vbs. Stop it with Ctrl + C. If you try to run it outside of a command window, it will work, but you'll only get updates when you press OK and you'll have to shut it down by pressing Ctrl+Alt+Del and killing the Windows Script Host task or rebooting. You should be connected to an access point before you start the script.
Here it is:
'bjs555monitor.vbs 'This script will continuously display the received signal 'strength of an active wireless connection in a command 'window. The update rate is once per second. Start it by 'typing cscript bjs555monitor.vbs at a command prompt. 'Stop it by pressing Ctrl + C. If you paste this script into a 'text editor, just save it with the name bjs555monitor.vbs '(or anything ending with .vbs) so that Windows will recognize 'it as a vbscript file. set objSwbemServices = GetObject("winmgmts:\\\\.\\root\\wmi") do while 1 set colInstances = objSwbemServices.ExecQuery _ ("Select * From MSNdis_80211_ReceivedSignalStrength "_ & "Where Active = True") for each objInstance in colInstances signal = objInstance.Ndis80211ReceivedSignalStrength & " dBm" next wscript.echo signal wscript.sleep(1000) loop
I found out something interesing using this script. I have a Linksys WUSB11v4 radio that I tried it on. When I look at the output, I see that all readings are multiples of 5 dB. It seems that the Linksys client doesn't report signal strength with resolution better than 5 dB. The other 2 radios I tried it on (Zonet ZEW2501 and Hawking HWU54G) both showed readings with resolutions of 1 dB. I'd be interested in finding out if all Linksys products show only crude approximations of signal strength.
Bruce
